Saltar al contenido principal
iPhone 6s Plus Display Assembly Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. iPhone 6s Plus Display Assembly Replacement, Pentalobe Screws: paso 1, imagen 1 de 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  2. iPhone 6s Plus Display Assembly Replacement, Opening Procedure: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Clamp
    $24.95
    Comprar
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  3. iPhone 6s Plus Display Assembly Replacement: paso 3, imagen 1 de 1
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 6s Plus Display Assembly Replacement: paso 4, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 4, imagen 2 de 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  5. iPhone 6s Plus Display Assembly Replacement: paso 5, imagen 1 de 3 iPhone 6s Plus Display Assembly Replacement: paso 5, imagen 2 de 3 iPhone 6s Plus Display Assembly Replacement: paso 5, imagen 3 de 3
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  6. iPhone 6s Plus Display Assembly Replacement: paso 6, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 6, imagen 2 de 2
    • Twist the spudger to widen the gap between the front panel and the rear case.
  7. iPhone 6s Plus Display Assembly Replacement: paso 7, imagen 1 de 3 iPhone 6s Plus Display Assembly Replacement: paso 7, imagen 2 de 3 iPhone 6s Plus Display Assembly Replacement: paso 7, imagen 3 de 3
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  8. iPhone 6s Plus Display Assembly Replacement: paso 8, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 8, imagen 2 de 2
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  9. iPhone 6s Plus Display Assembly Replacement: paso 9, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 9, imagen 2 de 2
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  10. iPhone 6s Plus Display Assembly Replacement: paso 10, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 10, imagen 2 de 2
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  11. iPhone 6s Plus Display Assembly Replacement: paso 11, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 11, imagen 2 de 2
    • Pull up on the small nub on the suction cup to remove it from the display.
  12. iPhone 6s Plus Display Assembly Replacement: paso 12, imagen 1 de 3 iPhone 6s Plus Display Assembly Replacement: paso 12, imagen 2 de 3 iPhone 6s Plus Display Assembly Replacement: paso 12, imagen 3 de 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  13. iPhone 6s Plus Display Assembly Replacement, Battery Connector: paso 13, imagen 1 de 1
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  14. iPhone 6s Plus Display Assembly Replacement: paso 14, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 14, imagen 2 de 2
    • Remove the battery connector bracket.
  15. iPhone 6s Plus Display Assembly Replacement: paso 15, imagen 1 de 3 iPhone 6s Plus Display Assembly Replacement: paso 15, imagen 2 de 3 iPhone 6s Plus Display Assembly Replacement: paso 15, imagen 3 de 3
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  16. iPhone 6s Plus Display Assembly Replacement: paso 16, imagen 1 de 3 iPhone 6s Plus Display Assembly Replacement: paso 16, imagen 2 de 3 iPhone 6s Plus Display Assembly Replacement: paso 16, imagen 3 de 3
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  17. iPhone 6s Plus Display Assembly Replacement, Display Assembly: paso 17, imagen 1 de 1
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  18. iPhone 6s Plus Display Assembly Replacement: paso 18, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 18, imagen 2 de 2
    • Remove the display cable bracket.
  19. iPhone 6s Plus Display Assembly Replacement: paso 19, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 19, imagen 2 de 2
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  20. iPhone 6s Plus Display Assembly Replacement: paso 20, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 20, imagen 2 de 2
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  21. iPhone 6s Plus Display Assembly Replacement: paso 21, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 21, imagen 2 de 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  22. iPhone 6s Plus Display Assembly Replacement: paso 22, imagen 1 de 2 iPhone 6s Plus Display Assembly Replacement: paso 22, imagen 2 de 2
Conclusión
17 personas más completaron esta guía.
Evan Noronha
Miembro Desde 02/05/15
223,232 Reputación
168 Guías creadas
3 comentarios
The most comprehensive and useful instructions I took the time to find. The screw placement annotations are very informative and handy. Well done. It helped me to flawlessly complete replacement of my screen and digitizer.
drav.stone - Contestar
I did everything step by step. After completing it all and putting the phone back together and turning it back on I noticed that the auto-brightness function doesn't work anymore.
Royce cummings - Contestar
Thanks so much Evan! I was very nervous about attemptong this myself - I’m a senior and never done anything like this before. Your guide (along with the video) gave me the confidence to give it a shot! So glad I did! :-)
CoffeeCup - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 7,178
