Saltar al contenido principal
iPhone 6 Pentalobe Screws Replacement
Qué necesitas
  1. iPhone 6 Pentalobe Screws Replacement, Pentalobe Screws: paso 1, imagen 1 de 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Conclusión
99 personas más completaron esta guía.
8 comentarios
What size screwdriver do I need to remove these screws?
ronrola - Contestar
P2 Pentalobe Screwdriver
sbrown9615 -
really? follow these steps in reverse to reinstall? it already is laughably short...
beautron7 - Contestar
also how is this moderate difficulty?
I have the correct screwdriver, but after taking out the original pentalobe screws, they will not screw back into the iPhone. Really bizarre. Do these screws get easily stripped?
dcs Bu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 49
Ultimos 30 días: 165
Todo El Tiempo: 63,003
