Introducción
Use this guide to remove or replace the home button in your iPhone 6.
Please note that only the phone's original home button assembly will be capable of using the Touch ID functionality. Installing a new home button will only restore ordinary home button functions, not the Touch ID features.
You can also use this guide to replace the following parts:
Qué necesitas
Resumen del Video
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Herramienta utilizada en este paso:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Herramienta utilizada en este paso:Magnetic Project Mat$19.95
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Remove the front panel assembly from the rear case.
Herramienta utilizada en este paso:iOpener$19.99
Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
Depending on your replacement part, you may need to remove the rubber gasket around your home button.
Use a set of tweezers to carefully pull the gasket up from the home button.
Be careful not to snag the gasket on the home button cable.
386 personas más completaron esta guía.
68 comentarios
is this the original home button?
My home button doesnt working while my touch id is working fine. I ask this repair shop he said , if u get this phone repaired, ur touch id wont working. How can i settle this down with free risk
جهاز أيفون 6 البصمة تخرب بسرعة
You can't update your phone when you don't have the original home button, any solutions?
I work at an Apple repair centre in based in the UK and we have recently encountered MAJOR issues with replacement home buttons. It turns out that home buttons are linked too the logic board on each handset due to the method in which Apple stores you biometric data. Due to this, to the greatest extent of our knowledge, any update (through setting on the phone, updating on the phone, updating through iTunes or resting on iTunes) will cause an ERROR 53 to occur. As of yet we have not be able to rescue a handset from this state. If any body has any further knowledge it would be massively appreciated, as a community we need to get to the bottom of this before anybody had any major disasters.
