Qué necesitas
Use a spudger to disconnect the Lightning connector ribbon cable from its socket on the logic board.
The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
