Introducción
使用这份指南来替换显示屏组件。显示屏组件包括Home键组件,前置摄像头组件,耳机喇叭,和液晶保护板。你需要做的就是拆掉旧的显示屏组件,把home键换到新显示屏组件上就好了。
如果你的替换显示屏不包括这些零件,请遵循以下显示屏面板指南.
在成功地更换显示屏组件之后,通过贴屏幕保护膜来保护屏幕不被划伤。
Resumen del Video
无论你使用什么工具,你需要确定你把整个显示屏拉起来了。
如果玻璃开始从塑料分离,如图一所示,在塑料框架和金属手机之间滑动塑料小撬棒,以撬出后机壳的金属夹。
握紧iSclack把手,打开它的吸盘钳口。
把你iPhone的底部放置在两个吸盘之间,紧紧靠住塑料的深度卡口。
上面吸盘应该刚好在home健的上方位置。
使用iSclack把手把钳口合上。把吸盘放到手机中间,并且把吸盘牢牢地按到iPhone屏幕上和机身底部。
握紧你的iPhone,然后合拢iSclack的把手,这样屏幕就和机身分离开来。
iSclack是专门设计用来打开你的iPhone的,它能够很好的保证在分离屏幕和机身时不扯断任何电线。
松开iSclack的吸盘。
跳过下面3步,直接到第9步。
请务必在维修继续前断开电池,如果不这样做的话,有时会导致手机运行太热和/或与触摸敏感问题。
当前面板组件底部和侧面夹扣被撬起后,拉动组件的底部使之远离后壳。
缓慢提升前面板组件跟后壳体成约90度。
要再组装你的设备,请使用逆序的方式。
要再组装你的设备,请使用逆序的方式。
870 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
81%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
37 comentarios
My brother in-law had water damage to his screen and the carrier was going to charge him and arm and a leg for a new phone so I ordered the complete display assembly from right here on iFixit that came with all the necessary tools. Took me a little over 5 minutes between repairing and chit chat to finish. It was a really easy repair and my brother in-law was never happier to have his phone back at a fraction of the cost the carrier was quoting.
Thanks for your guide for replace new touch screen
i had save one tiny screw from inside assembally :) :) :)
My display didn't shut down when i have a call and i put the phone near my ear! I plug my broken display and it work well but not the new one...please someone help! btw thanks for the guide and for the fast delivery
I know you posted this awhile ago, but if anyone else is wondering, how to fix the issue where the display won't turn off while on a phone call, You MUST transfer over the small plastic retaining brackets from the old display, and put them in the correct position! By correct position, I mean the two small transparent points need to line up with the receptors on your iPhone's front panel assembly (Camera, light sensor, mic).
This one is for Max:
Max, can you explain better what you mean by plastic retaining brackets? I'm about to swap my screen out and I wanna be able to do this
