Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Internal prerequisite.
Partes
No se especificaron partes.
  1. Use the edge of a plastic opening tool to gently peel the bottom right corner of the home button assembly from the display assembly.
    • Use the edge of a plastic opening tool to gently peel the bottom right corner of the home button assembly from the display assembly.
  2. Use a pair of tweezers to peel the home button assembly off the adhesive securing it to the display assembly. Remove the home button assembly from the display assembly.
    • Use a pair of tweezers to peel the home button assembly off the adhesive securing it to the display assembly.
    • Remove the home button assembly from the display assembly.
  3. Remove the home button from the home button gasket.
    • Remove the home button from the home button gasket.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,674
