Saltar al contenido principal
iPhone 4 Verizon Power Button Cable Replacement
Qué necesitas
  1. iPhone 4 Verizon Power Button Cable Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
  2. iPhone 4 Verizon Power Button Cable Replacement: paso 2, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement: paso 2, imagen 2 de 2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4 Verizon Power Button Cable Replacement: paso 3, imagen 1 de 1
    • Pinch the rear panel with your fingers, and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
  4. iPhone 4 Verizon Power Button Cable Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
  5. iPhone 4 Verizon Power Button Cable Replacement: paso 5, imagen 1 de 1
    • Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
  6. iPhone 4 Verizon Power Button Cable Replacement: paso 6, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement: paso 6, imagen 2 de 2
    • Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
    • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
    • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  7. iPhone 4 Verizon Power Button Cable Replacement, Dock Connector Cable: paso 7, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement, Dock Connector Cable: paso 7, imagen 2 de 2
    • Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
    • Remove the thin metal dock connector cable cover.
  8. iPhone 4 Verizon Power Button Cable Replacement: paso 8, imagen 1 de 1
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  9. iPhone 4 Verizon Power Button Cable Replacement: paso 9, imagen 1 de 1
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  10. iPhone 4 Verizon Power Button Cable Replacement: paso 10, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement: paso 10, imagen 2 de 2
    • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
    • Remove the pressure contact.
  11. iPhone 4 Verizon Power Button Cable Replacement: paso 11, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement: paso 11, imagen 2 de 2
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
    • When reconnecting the antenna wire be VERY certain that the round connector at the end of the wire is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connector.
  12. iPhone 4 Verizon Power Button Cable Replacement, Rear Camera: paso 12, imagen 1 de 1
    • Remove the following five screws:
    • Three 1.3 mm Phillips screws
    • One 1.5 mm Phillips screw
    • One 2.4 mm Phillips screw
  13. iPhone 4 Verizon Power Button Cable Replacement: paso 13, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement: paso 13, imagen 2 de 2
    • Lift the cable cover from its edge nearest the top of the iPhone.
    • Pull the cable cover tabs out of their slots cut into the EMI shield on the logic board and remove it from the iPhone.
  14. iPhone 4 Verizon Power Button Cable Replacement: paso 14, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement: paso 14, imagen 2 de 2
    • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
    • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
    • Remove the rear camera from the iPhone.
    • Be careful not to scratch the back of the display assembly after the removal of the rear facing camera.
  15. iPhone 4 Verizon Power Button Cable Replacement, Logic Board: paso 15, imagen 1 de 1
    • Disconnect the five cables near the top of the logic board in the following order:
    • Headphone jack/volume button cable
    • Power button cable
    • Front facing camera cable
    • Digitizer cable
    • Display data cable
    • To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
    • Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
  16. iPhone 4 Verizon Power Button Cable Replacement: paso 16, imagen 1 de 1
    • Remove the 1.5 mm Phillips #000 screw near the headphone jack.
  17. iPhone 4 Verizon Power Button Cable Replacement: paso 17, imagen 1 de 1
    • Lift the small grounding clip up off the logic board and remove it from the iPhone.
  18. iPhone 4 Verizon Power Button Cable Replacement: paso 18, imagen 1 de 1
    • Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna cable connector from the logic board.
    • When reconnecting the wifi ribbon connector to the mother board be VERY certain that the round connector at the end of the ribbon cable is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connection.
  19. iPhone 4 Verizon Power Button Cable Replacement: paso 19, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement: paso 19, imagen 2 de 2
    • If present, remove the piece of tape covering a Phillips screw near the power button.
    • Remove the 2.5 mm Phillips #000 screw securing the logic board near the power button.
    • Remove the 4.8 mm standoff screw near the headphone jack.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  20. iPhone 4 Verizon Power Button Cable Replacement: paso 21, imagen 1 de 1
    • Remove the 3.4 mm Phillips screw near the vibrator motor.
    • Remove the two 3.6 mm standoff screws along the side of the logic board nearest the battery opening.
  21. iPhone 4 Verizon Power Button Cable Replacement: paso 22, imagen 1 de 1
    • Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
    • Remove the logic board.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
    • There's a small rectangular rubber pad at the top of the logic board that prevents the display cables from chafing against the edge of the board. If it comes loose during your repair, make sure to position it correctly when reinstalling your logic board.
  22. iPhone 4 Verizon Power Button Cable Replacement: paso 23, imagen 1 de 1
    • Be sure not to lose the small grounding finger for the rear facing camera near the power button.
  23. iPhone 4 Verizon Power Button Cable Replacement, Earpiece Speaker: paso 24, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement, Earpiece Speaker: paso 24, imagen 2 de 2
    • Use the edge of a plastic opening tool to peel the earpiece speaker off the foam adhesive securing it to the iPhone.
    • If you wish to reuse the earpiece speaker, try not to tear the foam adhesive that secures it to the iPhone's case.
    • Remove the earpiece speaker.
    • The speaker may be glued to a ribbon cable. Use a second opening tool to hold the cable down.
  24. iPhone 4 Verizon Power Button Cable Replacement, Power Button Cable: paso 25, imagen 1 de 3 iPhone 4 Verizon Power Button Cable Replacement, Power Button Cable: paso 25, imagen 2 de 3 iPhone 4 Verizon Power Button Cable Replacement, Power Button Cable: paso 25, imagen 3 de 3
    • Remove the two 2.0 mm Phillips screws securing the power button bracket to the outer case.
    • Slightly pull the power button cable bracket away from the outer case.
    • If the power button happens to accidentally fall out, take note of the correct orientation. The metal loop should be facing downwards and the outward edges should be on top.
  25. iPhone 4 Verizon Power Button Cable Replacement: paso 26, imagen 1 de 1
    • Use the edge of a plastic opening tool to gently pry up the bracket above the void where the earpiece speaker was installed.
    • This bracket is captive to the outer case. It is not necessary to try to remove it.
  26. iPhone 4 Verizon Power Button Cable Replacement: paso 27, imagen 1 de 2 iPhone 4 Verizon Power Button Cable Replacement: paso 27, imagen 2 de 2
    • Use a plastic opening tool to gently peel up the power button cable from the outer case.
    • Remove the power button cable from the iPhone.
  27. iPhone 4 Verizon Power Button Cable Replacement: paso 28, imagen 1 de 1
    • Use a plastic opening tool to remove the metal power button bracket from the power button switch.
    • Transfer this bracket to your new power button cable.
Conclusión
84 personas más completaron esta guía.
3 comentarios
This one was a bit difficult with the routing of the cable, but overall easy for a first timer.
ltspenny - Contestar
My power button quit working. I bought the cable assembly and replaced it per these instructions. Everything seemed to work at first but later I noticed my phone kept trying to shut itself off. Any ideas what is causing this? It only seems to occur after I use the power button. It is almost as if it is getting stuck down.
rick - Contestar
Please remove your screen first, before replacing power button or sensor cable. I advise you to not dare attempt to remove those Step 25 screws (power button cable bracket ) while screen is mounted.
It is too risky! Display's ribbon cable interferes with driver access to these screws. While driving these screws, I unknowingly broke my display cable. It is actually a delicate circuit, not just a simple flexible ribbon. If I knew just how delicate is display cable, then I would not have ventured to perform this replacement. (In my case, only proximity sensor was not working; power and and ambient light sensor were both functioning. In my case, it was not worth breaking a pricy screen for sake of a cheap sensor.)
With a broken screen cable, iPhone endlessly repeats a diagnostic sound or vibration.
iPhone endlessly repeats the "power supply accepted" sound or vibration
unsubstantiated - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 39,651
