Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Archivada
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Archivada
Introducción
Be sure that you have the correct tools for the job. If not, make sure to get the right tools before starting.
  1. Here you can see the original cracked rear panel and the replacement panel. Next using a Phillips head screwdriver, remove the mounting screws at the bottom of the iPhone. Place them aside carefully as they are really small. Finally, once the screws are out gently apply pressure and slide the screen up to release the panel. Careful not to be too rough with it.
    • Here you can see the original cracked rear panel and the replacement panel.
    • Next using a Phillips head screwdriver, remove the mounting screws at the bottom of the iPhone. Place them aside carefully as they are really small.
    • Finally, once the screws are out gently apply pressure and slide the screen up to release the panel. Careful not to be too rough with it.
  2. Carefully place the replacement panel on to the iPhone back lining it up as close to the bottom as possible. Now again gently apply pressure as you slide the panel towards the bottom of the iPhone to lock it into place.
    • Carefully place the replacement panel on to the iPhone back lining it up as close to the bottom as possible.
    • Now again gently apply pressure as you slide the panel towards the bottom of the iPhone to lock it into place.
    • Replace the screws that you set aside earlier and be sure no to over tighten otherwise you will strip them.
Conclusión
21 personas más completaron esta guía.
Trekboy72
Miembro Desde 12/08/14
1,119 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 7,262
