Saltar al contenido principal
iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Resumen del Video
  1. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery., iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 1, imagen 1 de 3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery., iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 1, imagen 2 de 3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery., iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 1, imagen 3 de 3
    • Open iTunes. The iPhone must be connected to the PC and powered OFF.
    • ATTENTION, ATTENTION: You will lose all your data. Be sure that you have backup.
  2. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 2, imagen 1 de 3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 2, imagen 2 de 3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 2, imagen 3 de 3
    • Entering DFU mode.
    • Instruction you can read at the description.
    • iTunes has detected an iPhone in recovery mode.
  3. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 3, imagen 1 de 3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 3, imagen 2 de 3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 3, imagen 3 de 3
    • Select "Restore iPhone" and iTunes will download and install the latest firmware for your phone.
  4. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: paso 4, imagen 1 de 1
    • Your iPhone is factory restored now.
    • Did you do it successfully?
Conclusión
This guide does not need reassembly.
455 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,497 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,485 Guías creadas
99 comentarios
This is not flashing anything just resetting the iPhone...
Newbye - Contestar
You are wrong. This procedure reflash the firmware, but if your phone is already with the latest version, for you this will looks like full reset.
ZFix -
My iphone 4 is locked and i dont know the apple id so by doing this i can unlock it or not please help
mehtashivani44 - Contestar
If your phone is carrier locked or iCloud locked - no.
ZFix -
contact me to unlock iphone 4 icloud lock
Himanshu Rattan -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 79
Ultimos 30 días: 370
Todo El Tiempo: 503,043
