Saltar al contenido principal
Introducción
Use this guide to remove or replace the SIM card in your iPhone 11 Pro. This guide is for the physical SIM card only; the embedded SIM (eSIM) is silicon-based and cannot be removed.
  1. Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located near the side button on the edge of the iPhone. Press firmly to eject the tray. Press firmly to eject the tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located near the side button on the edge of the iPhone.
    • Press firmly to eject the tray.
  2. Remove the SIM card tray from the iPhone. The SIM card will fall out of the tray easily. When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
Conclusión
Una persona más ha completado esta guía.
Jeff Suovanen
Miembro Desde 06/08/13
355,146 Reputación
258 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
138 Miembros
16,454 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 20
Ultimos 7 días: 146
Ultimos 30 días: 474
Todo El Tiempo: 7,000
