Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Prerequisite only. This guide shows how to disconnect the iPad Pro's display assembly.
  1. Remove the three 1.3 mm Phillips #000 screws securing the display cable bracket.
    • Remove the three 1.3 mm Phillips #000 screws securing the display cable bracket.
  2. Remove the display cable bracket. Remove the display cable bracket.
    • Remove the display cable bracket.
  3. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
  4. Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket. Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
    • Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
  5. Repeat the previous step for the two remaining connectors. Repeat the previous step for the two remaining connectors.
    • Repeat the previous step for the two remaining connectors.
  6. Remove the display assembly. If you are reusing the original display assembly, follow this display adhesive application guide to apply replacement display adhesive during reassembly.
Conclusión
Arthur Shi
Miembro Desde 03/01/18
123,559 Reputación
365 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
129 Miembros
12,526 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 41
