Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Prereq for removing the logic board. Battery is out.
Partes
No se especificaron partes.
  1. Remove two 1.4 mm #00 Phillips screws securing the left and right speakers to the rear case.
    • Remove two 1.4 mm #00 Phillips screws securing the left and right speakers to the rear case.
  2. Insert the tip of a spudger into the gap between the left speaker and the bottom left side of the rear case. Pry around the bottom of the speaker, sliding it out from its recess in the rear case.
    • Insert the tip of a spudger into the gap between the left speaker and the bottom left side of the rear case.
    • Pry around the bottom of the speaker, sliding it out from its recess in the rear case.
  3. Once enough of the speaker is exposed, grasp it and pull it away from its recess in the rear case. Remove the left speaker from the iPad.
    • Once enough of the speaker is exposed, grasp it and pull it away from its recess in the rear case.
    • Remove the left speaker from the iPad.
  4. Use the tip of a spudger to slide the right speaker slightly toward the outside of the iPad. Use the tip of a spudger to slide the right speaker slightly toward the outside of the iPad.
    • Use the tip of a spudger to slide the right speaker slightly toward the outside of the iPad.
  5. Insert the tip of a spudger into the gap between the right speaker and the bottom right corner of the case. Pry the speaker out from its recess in the rear case.
    • Insert the tip of a spudger into the gap between the right speaker and the bottom right corner of the case.
    • Pry the speaker out from its recess in the rear case.
  6. Once enough of the speaker is exposed, grasp it and pull it away from its slot in the rear case. Remove the right speaker from the iPad.
    • Once enough of the speaker is exposed, grasp it and pull it away from its slot in the rear case.
    • Remove the right speaker from the iPad.
  7. Remove two 2.8 mm Phillips #00 screws from the base of the Lightning connector.
    • Remove two 2.8 mm Phillips #00 screws from the base of the Lightning connector.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 92
