Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu iPad ClamCase, utiliza nuestros manuales de servicio .
  1. iPad ClamCase, iPad ClamCase: paso 1, imagen 1 de 2 iPad ClamCase, iPad ClamCase: paso 1, imagen 2 de 2
    • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
    • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
  2. iPad ClamCase: paso 2, imagen 1 de 2 iPad ClamCase: paso 2, imagen 2 de 2
    • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
    • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
  3. iPad ClamCase: paso 3, imagen 1 de 2 iPad ClamCase: paso 3, imagen 2 de 2
    • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
    • Be patient, the thin black covering might be really stuck to the bottom.
  4. iPad ClamCase: paso 4, imagen 1 de 1
    • Once the thin black covering is removed, you will see 15 screws.
    • Use the T6 Torx screwdriver to remove the screws.
  5. iPad ClamCase: paso 5, imagen 1 de 1
    • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
  6. iPad ClamCase: paso 6, imagen 1 de 1
    • You are done.
Izmet Barranco
Miembro Desde 12/12/12
213 Reputación
1 Guía escrita
2 comentarios
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - Contestar
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 7,727
