Saltar al contenido principal
iPad 4 Wi-Fi Headphone Jack Cable Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. iPad 4 Wi-Fi Headphone Jack Cable Replacement, Headphone Jack Cable: paso 1, imagen 1 de 3 iPad 4 Wi-Fi Headphone Jack Cable Replacement, Headphone Jack Cable: paso 1, imagen 2 de 3 iPad 4 Wi-Fi Headphone Jack Cable Replacement, Headphone Jack Cable: paso 1, imagen 3 de 3
    • Use tweezers to peel back and remove the piece of electrical tape covering the headphone jack assembly cable connector.
    • Using the tip of a spudger, flip up the retaining flap on both of the ZIF connectors securing the headphone jack cable to the logic board.
  2. iPad 4 Wi-Fi Headphone Jack Cable Replacement: paso 2, imagen 1 de 2 iPad 4 Wi-Fi Headphone Jack Cable Replacement: paso 2, imagen 2 de 2
    • Slide the flat end of a spudger underneath the headphone jack assembly cable, releasing the adhesive securing it to the rear aluminum frame.
    • Pull the headphone jack assembly cable straight out of its socket on the logic board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 36
