Saltar al contenido principal
iPad 4 Wi-Fi Headphone Jack Assembly Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. iPad 4 Wi-Fi Headphone Jack Assembly Replacement, Headphone Jack Assembly: paso 1, imagen 1 de 1
    • Carefully move, but do not remove the front-facing camera ribbon cable aside with the flat edge of a spudger.
  2. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 2, imagen 1 de 2 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 2, imagen 2 de 2
    • Peel back and remove the adhesive tape covering the headphone jack assembly.
  3. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 3, imagen 1 de 1
    • Using the tip of the spudger, flip up the retaining flap on the microphone cable ZIF connector.
  4. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 4, imagen 1 de 2 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 4, imagen 2 de 2
    • Insert the tip of the spudger underneath the microphone ribbon cable and carefully push it out from its socket on the ZIF connector.
    • Use the flat edge of a spudger to move the microphone ribbon cable aside.
  5. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 5, imagen 1 de 1
    • Flip up the retaining flap securing the volume/power button ribbon cable connector to the headphone jack assembly board.
  6. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 6, imagen 1 de 2 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 6, imagen 2 de 2
    • Push the volume button ribbon cable from its ZIF connector.
    • Gently bend the volume button ribbon cable upwards to move it aside.
  7. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 7, imagen 1 de 3 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 7, imagen 2 de 3 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 7, imagen 3 de 3
    • Remove the following screws from the headphone jack assembly:
    • Five 2.6 mm Phillips #0
    • Two 2.2 mm Wide Head Phillips #00
    • Two 2.6 mm Phillips #00
    • These screws are angled into the aluminum frame. Be sure to hold the screwdriver so that the screwdriver is in line with the screw, to avoid stripping the screw.
  8. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 8, imagen 1 de 1
    • Holding onto the ribbon cable of the headphone jack assembly, carefully pull the assembly upwards towards the top of the device.
  9. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 9, imagen 1 de 2 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: paso 9, imagen 2 de 2
    • Grasping the headphone jack assembly with one hand, pull the assembly from the iPad, minding any cables that may get caught.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 38
