Saltar al contenido principal
iPad 3G Dock Connector Cable Replacement
Qué necesitas
  1. iPad 3G Dock Connector Cable Replacement, Display Assembly: paso 1, imagen 1 de 3 iPad 3G Dock Connector Cable Replacement, Display Assembly: paso 1, imagen 2 de 3 iPad 3G Dock Connector Cable Replacement, Display Assembly: paso 1, imagen 3 de 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad 3G Dock Connector Cable Replacement: paso 2, imagen 1 de 2 iPad 3G Dock Connector Cable Replacement: paso 2, imagen 2 de 2
    • The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same.
    • Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
  3. iPad 3G Dock Connector Cable Replacement: paso 3, imagen 1 de 2 iPad 3G Dock Connector Cable Replacement: paso 3, imagen 2 de 2
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    • Pry the display assembly away from the rear panel.
  4. iPad 3G Dock Connector Cable Replacement: paso 4, imagen 1 de 2 iPad 3G Dock Connector Cable Replacement: paso 4, imagen 2 de 2
    • Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
    • Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
  5. iPad 3G Dock Connector Cable Replacement: paso 5, imagen 1 de 1
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not excessively lift the display assembly off the rest of the iPad, as a fragile antenna cable with very little slack still connects the two components.
  6. iPad 3G Dock Connector Cable Replacement: paso 6, imagen 1 de 1
    • Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
  7. iPad 3G Dock Connector Cable Replacement: paso 7, imagen 1 de 1
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
  8. iPad 3G Dock Connector Cable Replacement: paso 8, imagen 1 de 3 iPad 3G Dock Connector Cable Replacement: paso 8, imagen 2 de 3 iPad 3G Dock Connector Cable Replacement: paso 8, imagen 3 de 3
    • Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
  9. iPad 3G Dock Connector Cable Replacement: paso 9, imagen 1 de 1
    • Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  10. iPad 3G Dock Connector Cable Replacement: paso 10, imagen 1 de 2 iPad 3G Dock Connector Cable Replacement: paso 10, imagen 2 de 2
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
  11. iPad 3G Dock Connector Cable Replacement: paso 11, imagen 1 de 1
    • Remove the display assembly from the rear panel assembly.
  12. iPad 3G Dock Connector Cable Replacement, Dock Connector Cable: paso 12, imagen 1 de 1
    • Remove the two 4.56 mm T5 Torx screws securing the dock connector cable to the main board.
  13. iPad 3G Dock Connector Cable Replacement: paso 13, imagen 1 de 1
    • Remove the single 2.84 mm T5 Torx screw connecting the dock connector cable to the rear case assembly.
  14. iPad 3G Dock Connector Cable Replacement: paso 14, imagen 1 de 1
    • Remove the two 2.84 mm T5 Torx screws securing the dock connector cable to the rear panel assembly.
  15. iPad 3G Dock Connector Cable Replacement: paso 15, imagen 1 de 1
    • Carefully remove the plastic cover over the WiFi/Bluetooth board and dock connector cable using an iPod opening tool.
  16. iPad 3G Dock Connector Cable Replacement: paso 16, imagen 1 de 1
    • Pry the Wi-Fi and Bluetooth antennas up off their respective sockets on the Wi-Fi/Bluetooth board.
  17. iPad 3G Dock Connector Cable Replacement: paso 17, imagen 1 de 1
    • Remove the dock connector cable from the rear panel assembly.
Conclusión
29 personas más completaron esta guía.
Un comentario
After replacing the Dock Connector Cable you may find your iPad stuck in Recovery Mode, this is due to changing the WiFi chip (Included on the Dock Cable), the WiFi address is different and cannot be recognised. Just Restore in iTunes and all will be ok.
Sam112 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 24,254
