Saltar al contenido principal
iON SnapCam 1045 Wearable HD Video Camera Battery
Qué necesitas
  1. iON SnapCam 1045 Wearable HD Video Camera Battery, Battery: paso 1, imagen 1 de 1
    • Detach the magnetic clip from the bottom of the camera.
    • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
  2. iON SnapCam 1045 Wearable HD Video Camera Battery: paso 2, imagen 1 de 1
    • Use a spudger to gently detach the memory card and USB slot cover.
  3. iON SnapCam 1045 Wearable HD Video Camera Battery: paso 3, imagen 1 de 1
    • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
    • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
  4. iON SnapCam 1045 Wearable HD Video Camera Battery: paso 4, imagen 1 de 2 iON SnapCam 1045 Wearable HD Video Camera Battery: paso 4, imagen 2 de 2
    • Once again use the spudger to gently open the encasement.
    • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
    • The Battery can be safely detached and replaced.
Conclusión
Una persona más ha completado esta guía.
Olakunle
Miembro Desde 11/11/17
102 Reputación
1 Guía escrita
Equipo
IUPUI, Team S3-G3, Wilson Fall 2017 Miembro de IUPUI, Team S3-G3, Wilson Fall 2017
IUPUI-WILSON-F17S3G3
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 695
