Introducción
Use this guide to remove the SATA cable.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
Qué necesitas
Herramienta utilizada en este paso:iMac Intel 27" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
Herramienta utilizada en este paso:Plastic Cards$2.99
Set the iMac face-up on a table.
Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
If there is a wire or cable underneath adhesive tape, always pull the tape off first.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Pull straight up on the SATA data/power cable to disconnect it from the drive.
Disconnect the power supply control cable from the power supply.
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
Leftmost
Top
Upper right
Lower right
Pull up on the SATA power cable connector to disconnect it.
Unplug the SATA data cable connector by depressing its locking tab and pulling straight up on the connector.
Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
7 personas más completaron esta guía.
5 comentarios
Did you ever find it? I agree with the "!@#$ "
Hi Rovipq,
I found out that the part number for the cable is: Apple No. 923-00092 for an iMac 5k late 2014 with internal SSD Drive only (No Fusion Drive!).
The cable was a while available at iFixit but I actually it's out of stock. This is really a !&&* of a work and I don't know if I can manage it so easily... Maybe I will go for the external SSD via USB :-)
