Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
iMac Intel 27" EMC 2390 SD Board Replacement
Qué necesitas
  1. iMac Intel 27" EMC 2390 SD Board Replacement, Glass Panel: paso 1, imagen 1 de 3 iMac Intel 27" EMC 2390 SD Board Replacement, Glass Panel: paso 1, imagen 2 de 3 iMac Intel 27" EMC 2390 SD Board Replacement, Glass Panel: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Heavy-Duty Suction Cups (Pair)
    $16.95
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
    Pregunta a FixBot
    Agregar Comentario
  2. iMac Intel 27" EMC 2390 SD Board Replacement: paso 2, imagen 1 de 3 iMac Intel 27" EMC 2390 SD Board Replacement: paso 2, imagen 2 de 3 iMac Intel 27" EMC 2390 SD Board Replacement: paso 2, imagen 3 de 3
    • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
    • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
    Pregunta a FixBot
    Agregar Comentario
  3. iMac Intel 27" EMC 2390 SD Board Replacement, Display: paso 3, imagen 1 de 1
    • Remove the eight T10 Torx screws securing the LCD to the outer case.
    Pregunta a FixBot
    Agregar Comentario
  4. iMac Intel 27" EMC 2390 SD Board Replacement: paso 4, imagen 1 de 3 iMac Intel 27" EMC 2390 SD Board Replacement: paso 4, imagen 2 de 3 iMac Intel 27" EMC 2390 SD Board Replacement: paso 4, imagen 3 de 3
    • Carefully lay the iMac stand-side down on a flat surface.
    • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
    • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
    • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side. A pencil or pen can be placed under the top edge of the display, parallel to the top edge and extending past the edge of the computer, to keep the first side propped up while lifting the second.
    • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
    Pregunta a FixBot
    Agregar Comentario
  5. iMac Intel 27" EMC 2390 SD Board Replacement: paso 5, imagen 1 de 2 iMac Intel 27" EMC 2390 SD Board Replacement: paso 5, imagen 2 de 2
    • Use a pair of tweezers to pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • On some iMacs this may not be a ribbon cable but four separate, very fine and very fragile wires. Be very careful, if the tweezers slip off the plug, you will very likely pull a wire out of the assembly.
    Pregunta a FixBot
    Agregar Comentario
  6. iMac Intel 27" EMC 2390 SD Board Replacement: paso 6, imagen 1 de 1
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    Pregunta a FixBot
    Agregar Comentario
  7. iMac Intel 27" EMC 2390 SD Board Replacement: paso 7, imagen 1 de 1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be very careful when disconnecting this cable as both the cable connector and logic board socket are extremely fragile. When reconnecting the cable later, use as little force as possible.
    Pregunta a FixBot
    Agregar Comentario
  8. iMac Intel 27" EMC 2390 SD Board Replacement: paso 8, imagen 1 de 1
    • Lift the display for enough clearance to disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable. The thermal sensor connector socket is very fragile, so be very careful when you connect back the sensor cable.
    Pregunta a FixBot
    Agregar Comentario
  9. iMac Intel 27" EMC 2390 SD Board Replacement: paso 9, imagen 1 de 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case.
    Pregunta a FixBot
    Agregar Comentario
  10. iMac Intel 27" EMC 2390 SD Board Replacement, SD Board: paso 10, imagen 1 de 1
    • Grasp the SD board cable connector with a pair of tweezers and pull it straight away from its socket on the SD board.
    Pregunta a FixBot
    Agregar Comentario
  11. iMac Intel 27" EMC 2390 SD Board Replacement: paso 11, imagen 1 de 1
    • Remove the single T8 Torx screw securing the SD board to the outer case.
    Pregunta a FixBot
    Agregar Comentario
  12. iMac Intel 27" EMC 2390 SD Board Replacement: paso 12, imagen 1 de 1
    • Lift the free end of the SD board to clear the plastic optical drive fan body, then pull it away from the edge of the outer case case to clear the two mounting pins.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Brett Hartt
Miembro Desde 04/12/10
132,135 Reputación
144 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 122
25,808 Guías creadas
1Guía Comentario
One must consider, the USP based card adapter is like five dollars.
When I tell customers this, they usually get that instead of paying me $100 plus parts to repair it
Kevin McCartney - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 19
Ultimos 30 días: 128
Todo El Tiempo: 8,266
