Introducción
Backlight not working? Use this guide to replace a broken LED driver board.
Qué necesitas
Herramienta utilizada en este paso:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Remove the four T10 Torx screws securing the LED driver board to the outer case.
11 personas más completaron esta guía.
