Qué necesitas
Herramienta utilizada en este paso:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
17 personas más completaron esta guía.
3Guía Comentarios
Goods councils.
The glass of my iMac is broken and I want to fix it now. I consider to use a frame instead of a new glass in order to reduce reflections. I saw such a frame on macframe dot com and berlin1000 dot com. I wonder if anybody knows the exact measurements of the glass or has a technical drawing of it. If so, I would be able to laser cut it on my own.
Do everything in your power to avoid touching the inside of the glass with your fingers, or the LCD. Please give me his fingerprints is like washing and oiled animal with water
