Introducción
Use this guide to replace a faulty Bluetooth Board.
Qué necesitas
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Disconnect the Bluetooth cable by pulling its connector away from the socket on the Bluetooth board.
5 personas más completaron esta guía.
