Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
iMac Intel 27" EMC 2390 Access Door Replacement
Qué necesitas
  1. iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: paso 1, imagen 1 de 2 iMac Intel 27" EMC 2390 Access Door Replacement, Access Door: paso 1, imagen 2 de 2
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
Conclusión
12 personas más completaron esta guía.
1Guía Comentario
Easy mode. Note that the bits is called PZ1 most screwdriver sets. Also known as Japanese Phillips, the bid comes to a + instead of to a point. A 2.0 flathead will also turn the screw
Kevin McCartney - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 85
Todo El Tiempo: 9,784
