Saltar al contenido principal
iMac Intel 27" EMC 2309 and 2374 superdrive fixit
Qué necesitas
  1. iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Optical Drive: paso 1, imagen 1 de 1
    • Remove the four T10 Torx screws securing the optical drive to the outer case.
  2. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 2, imagen 1 de 1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
  3. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 3, imagen 1 de 2 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 3, imagen 2 de 2
    • Insert a spudger between the optical drive connector and the optical drive.
    • Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
  4. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 4, imagen 1 de 1
    • Lift the left edge of the optical drive slightly and pull it away from the right side of the outer case.
    • During reassembly, note that there are two holes in the optical drive face plate into which two stubby plastic posts must engage for proper positioning.
  5. iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Optical Drive: paso 5, imagen 1 de 2 iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Optical Drive: paso 5, imagen 2 de 2
    • Peel back the portion of aluminum tape highlighted in red, leaving the rest attached to the black plastic optical drive bracket.
    • It is not necessary to peel all of the EMI tape off the optical drive bracket.
  6. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 6, imagen 1 de 2 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 6, imagen 2 de 2
    • Remove the two T10 Torx screws from each side of the optical drive (four screws total).
  7. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 7, imagen 1 de 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 7, imagen 2 de 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 7, imagen 3 de 3
    • Use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
    • Rotate the optical drive bracket slightly away from the optical drive.
    • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
  8. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 8, imagen 1 de 2 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: paso 8, imagen 2 de 2
    • Use the tip of a spudger to peel back the piece of foam tape covering the optical drive thermal sensor.
    • Use the flat end of a spudger to carefully pry the thermal sensor up off the adhesive securing it to the optical drive.
    • If you have a disc or anything else stuck inside your optical drive, we have a guide to fix it.
    • Follow all super drive replacement steps for disassembly. Step 8 is absolutely unnecessary for the repair. Do not peel off the sensor from the optical drive.
    • Once the reader has been disassembled, all you have to do is unscrew the 5 small screws from the reader cover (the side where there are the labels). Remove the cover once the screws have been removed;
    • Plug in your vacuum cleaner and gently vacuum the entire interior, including the lens (beware of vacuum cleaners that are too powerful).
    • With a cotton swab previously dipped in rubbing alcohol, gently clean the lens.
    • reassemble the cover with the screws and reassemble everything.
    • Once everything is reassembled, start and cross your fingers. Usually it's just a dust issue.
    • Enjoy!!!
Conclusión
To reassemble your device, follow the instructions in reverse order.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ HelloMacOS nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Quentin Hindley
Miembro Desde 02/08/19
73 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 31
Todo El Tiempo: 378
