Introducción
Use this guide to replace a faulty camera board.
Qué necesitas
Herramienta utilizada en este paso:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Remove the two T10 Torx screws securing the camera board to the outer case.
2 personas más completaron esta guía.
