Introducción
Follow the steps in this guide to remove or replace the heat sink in a 21.5" Retina 4K Late 2015 iMac.
Make sure to follow our thermal paste application guide after you have removed your heat sink.
Qué necesitas
Herramienta utilizada en este paso:iMac Intel 21.5" Cardboard Service Wedge$4.99
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Herramienta utilizada en este paso:Plastic Cards$2.99
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
Hold the display with one hand while using your other hand to unplug the display power cable.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Gently pull the right speaker cable connector straight down and out of its socket on the logic board.
Remove the following T10 Torx screws securing the hard drive brackets to the iMac:
Two 21 mm screws
One 9 mm screw
One 27 mm screw
Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
Gently pull the fan cable connector straight out of its socket on the logic board.
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
Remove the 7.3 mm T8 Torx screw securing the hard drive tray to the rear enclosure.
Gently pull the left speaker cable straight out of its socket on the logic board.
While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
Loosen but do not remove the four captive T8 screws securing the heat sink over the CPU.
Remove the two 5.4 mm T8 screws securing the heat pipe to the logic board.
