Introducción
If the fan in your iMac Intel 21.5" EMC 3068 is faulty, failing, or badly clogged with dust, use this guide to replace it and return your iMac to cool and quiet operation.
Some images in this guide use a 2015 iMac, which has minor visual differences. These differences do not affect the repair procedure.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Hold the display with one hand while using your other hand to unplug the display power cable.
Gently pull the fan cable connector straight away from its socket on the logic board.
