Introducción
Reclaim your chat capabilities, use this guide to replace your combination iSight camera and microphone cable.
Herramientas
Partes
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
While holding the display up with one hand, use the other hand to unplug the display power cable.
Use the tip of a spudger to flip down the metal retaining bracket on the iSight camera cable.
2 personas más completaron esta guía.
Un Comentario
Excellently described procedure - it worked ok not disconnecting the AC power cable. Only item missed was to disconnect the right speaker - and then not to forget about keeping it out ready to connect when reinstating the mother board!
Thank you very much
