Saltar al contenido principal
iMac Intel 21.5" EMC 2428 Access Door Replacement
Qué necesitas
  1. iMac Intel 21.5" EMC 2428 Access Door Replacement, Access Door: paso 1, imagen 1 de 2 iMac Intel 21.5" EMC 2428 Access Door Replacement, Access Door: paso 1, imagen 2 de 2
    • Unplug your iMac's AC cord along with any peripheral devices.
    • Lay your iMac face-down on a soft, clean surface as shown.
    • Be sure there isn't any dirt or debris on your work surface, as it may scratch the glass panel on the front of your iMac. We recommend placing a towel between the iMac and the work surface.
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • All three screws will remain captive in the access door.
    • Remove the access door.
Conclusión
12 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 38
Todo El Tiempo: 8,053
