Introducción
Use this guide to replace the SD reader board.
Qué necesitas
Herramienta utilizada en este paso:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the tip of a spudger to push the SD board cable connector out of its socket.
Una persona más ha completado esta guía.
