Introducción
Use this guide to replace a broken camera.
Qué necesitas
Herramienta utilizada en este paso:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the two 5.2 mm shouldered T10 Torx screws securing the camera board to the outer case.
Una persona más ha completado esta guía.
