Saltar al contenido principal
iMac Intel 21.5" EMC 2308 RAM 1333 MHz
Qué necesitas
  1. iMac Intel 21.5" EMC 2308 RAM 1333 MHz, Introduction: paso 1, imagen 1 de 1
    • So, here's the catch: this logic board officially only supports the DDR3 PC3-8500, which runs at 1066MHz, but that's not entirely true. Its 4 slots supports 1333 MHz. You can try other capacities over what was used on my setup, but I cannot guarantee that it will work.
  2. iMac Intel 21.5" EMC 2308 RAM 1333 MHz: paso 2, imagen 1 de 1
    • 3 slots running at 1333 MHz each.
  3. iMac Intel 21.5" EMC 2308 RAM 1333 MHz: paso 3, imagen 1 de 1
    • This is the configuration layout that you should follow (Livre means "Free"), otherwise it won't work in my setup.
  4. iMac Intel 21.5" EMC 2308 RAM 1333 MHz, Exact Models Used: paso 4, imagen 1 de 2 iMac Intel 21.5" EMC 2308 RAM 1333 MHz, Exact Models Used: paso 4, imagen 2 de 2
    • Please note that probably the only memories supported by the Logic Board in higher frequencies are the ones with 4 chips on front and 4 chips on the back.
    • 1 x 4 GB
    • 2 x 2 GB
Conclusión
There's a chance that your iMac will power on with the coolers at maximum speed. If this happens, just turn the iMac off normally and remove the power cord from power, wait 20 seconds and power it on normally.
Gabriel
Miembro Desde 12/05/18
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 607
