1. So, here's the catch: this logic board officially only supports the DDR3 PC3-8500, which runs at 1066MHz, but that's not entirely true. Its 4 slots supports 4264 MHz in total. You can try other capacities over what was used on my setup, but I cannot guarantee that it will work.
    • So, here's the catch: this logic board officially only supports the DDR3 PC3-8500, which runs at 1066MHz, but that's not entirely true. Its 4 slots supports 4264 MHz in total. You can try other capacities over what was used on my setup, but I cannot guarantee that it will work.
  2. So, if you use 3 slots running at 1333 MHz each, you'll get 3999 MHz in total, which is still inside the budget.
    • So, if you use 3 slots running at 1333 MHz each, you'll get 3999 MHz in total, which is still inside the budget.
    • This is the configuration layout that you should follow (Livre means "Free"), otherwise it won't work.
    • Please note that probably the only memories supported by the Logic Board in higher frequencies are the ones with 4 chips on front and 4 chips on the back.
    • 1 x 4 GB
    • 2 x 2 GB
Conclusión
There's a chance that your iMac will power on with the coolers at maximum speed. If this happens, just turn the iMac off normally and remove the power cord from power, wait 20 seconds and power it on normally.
Gabriel
Miembro Desde 05/12/18
109 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 7
Últimos 30 Días: 42
Todo El Tiempo: 63
