Introducción
Use this guide to replace a broken Bluetooth board.
Qué necesitas
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the flat end of a spudger to pry the Bluetooth antenna cable connector up off the Bluetooth board.
2 personas más completaron esta guía.
Un comentario
Seriously this is so incomplete! What about the cable that connects the Bluetooth to the logic board!?!??? Like this is so half way explanatory!
