Introducción
Use this guide to replace the headphone/microphone jacks on your iMac.
Herramientas
Partes
No se especificaron partes.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Disconnect the audio port cable by pulling its connector toward the right side of the iMac.
De-route the audio port cable from the outer case.
3 personas más completaron esta guía.
