Introducción
Replace a broken AirPort card to regain Wi-Fi connectivity.
Herramientas
Partes
No se especificaron partes.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Use the flat end of a spudger to pry both AirPort antenna cable connectors up off the AirPort card.
2 personas más completaron esta guía.
