Saltar al contenido principal
iMac Intel 20" EMC 2266 RAM Replacement
Qué necesitas
  1. iMac Intel 20" EMC 2266 RAM Replacement, Access Door: paso 1, imagen 1 de 1
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 20" EMC 2266 RAM Replacement, RAM: paso 2, imagen 1 de 2 iMac Intel 20" EMC 2266 RAM Replacement, RAM: paso 2, imagen 2 de 2
    • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay.
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  3. iMac Intel 20" EMC 2266 RAM Replacement: paso 3, imagen 1 de 1
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
Conclusión
91 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 32
Todo El Tiempo: 37,718
