Introducción
Remove your access door to replace RAM chips or to open the case of your iMac.
Qué necesitas
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
10 personas más completaron esta guía.
