Saltar al contenido principal
iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement
  1. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement, Power On Button: paso 1, imagen 1 de 1
    • To get to the power button first remove the hard drive fan as seen in other guides.
  2. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: paso 2, imagen 1 de 1
    • This is a picture of the button in place with the connector to the logic board removed.
    • There are three plastic pins protruding up from the main back case that the button fits over. They appear to be slightly melted and mashed to hold it in place. I used a pocket knife to pry it up and off the posts.
  3. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: paso 3, imagen 1 de 2 iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: paso 3, imagen 2 de 2
    • Here it is with the back plate of the button pried off. This exposes a white plastic washer under it.
  4. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: paso 4, imagen 1 de 1
    • The center of the washer has a center locking pin to correctly place it on the back of the button. The washer is concave and the concave side faces the button, This gives the button a spring to it so that it will pop back out.
  5. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: paso 5, imagen 1 de 2 iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: paso 5, imagen 2 de 2
    • This is he back of the button that will now just push out. Picture #2 is with the button removed.
  6. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: paso 6, imagen 1 de 1
    • Test the button to see if it works.
    • After replacing the button, use something (like a low temperature soldering iron) that will melt the tops of the white plastic pegs to secure the button in place.
Conclusión
4 personas más completaron esta guía.
mayer
Miembro Desde 01/04/10
685,280 Reputación
12 Guías creadas
Equipo
MacHale Enterprises Miembro de MacHale Enterprises
Business
1 Miembro
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 13,836
