Introducción
Use this guide to replace or upgrade your optical drive...or both!
Qué necesitas
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
Remove the two 3.7 mm T6 Torx screws securing the optical drive connector board to the optical drive.
8 personas más completaron esta guía.
