Introducción
Regain Bluetooth functionality by replacing the Bluetooth board.
Qué necesitas
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
Un comentario
Greetings Walter Galan, I would like to know if I can install this iMac G5 20" Model A1076 Bluetooth board into my iMac 21 system, it say’s that no wireless is installed.
Please Advise!
Thank You In Advance & Have A Good One!!!.
R.Askew
