Saltar al contenido principal
iMac G5 17" Model A1144 RAM Replacement
Qué necesitas
  1. iMac G5 17" Model A1144 RAM Replacement, Access Door: paso 1, imagen 1 de 1
    • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • These screws are captive in the access door.
  2. iMac G5 17" Model A1144 RAM Replacement: paso 2, imagen 1 de 1
    • Remove the access door from your iMac.
  3. iMac G5 17" Model A1144 RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Insert your fingers into the two RAM arms and pull both arms toward yourself to eject the RAM chip.
  4. iMac G5 17" Model A1144 RAM Replacement: paso 4, imagen 1 de 1
    • Slide the RAM chip straight out of its socket.
    • Make sure both RAM arms are fully rotated outward before reinstalling your RAM chip.
Conclusión
12 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 17,473
