Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
iMac G5 17" Model A1144 Front Bezel Replacement
Qué necesitas
  1. iMac G5 17" Model A1144 Front Bezel Replacement, Access Door: paso 1, imagen 1 de 1
    • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • These screws are captive in the access door.
    Pregunta a FixBot
    Agregar Comentario
  2. iMac G5 17" Model A1144 Front Bezel Replacement: paso 2, imagen 1 de 1
    • Remove the access door from your iMac.
    Pregunta a FixBot
    Agregar Comentario
  3. iMac G5 17" Model A1144 Front Bezel Replacement, Front Bezel: paso 3, imagen 1 de 1
    • Remove the three T8 Torx screws securing the front bezel to the rear panel.
    Pregunta a FixBot
    Agregar Comentario
  4. iMac G5 17" Model A1144 Front Bezel Replacement: paso 4, imagen 1 de 2 iMac G5 17" Model A1144 Front Bezel Replacement: paso 4, imagen 2 de 2
    • Orient the iMac face-up, on its backside.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
    Pregunta a FixBot
    Agregar Comentario
  5. iMac G5 17" Model A1144 Front Bezel Replacement: paso 5, imagen 1 de 1
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
    Pregunta a FixBot
    Agregar Comentario
  6. iMac G5 17" Model A1144 Front Bezel Replacement: paso 6, imagen 1 de 3 iMac G5 17" Model A1144 Front Bezel Replacement: paso 6, imagen 2 de 3 iMac G5 17" Model A1144 Front Bezel Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
    Pregunta a FixBot
    Agregar Comentario
  7. iMac G5 17" Model A1144 Front Bezel Replacement: paso 7, imagen 1 de 1
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
    Pregunta a FixBot
    Agregar Comentario
  8. iMac G5 17" Model A1144 Front Bezel Replacement: paso 8, imagen 1 de 1
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
    Pregunta a FixBot
    Agregar Comentario
  9. iMac G5 17" Model A1144 Front Bezel Replacement: paso 9, imagen 1 de 2 iMac G5 17" Model A1144 Front Bezel Replacement: paso 9, imagen 2 de 2
    • Disconnect both the camera and microphone cables.
    Pregunta a FixBot
    Agregar Comentario
  10. iMac G5 17" Model A1144 Front Bezel Replacement, Camera Board: paso 10, imagen 1 de 1
    • Lay the bezel front side down on a table.
    • If necessary, peel back the tape covering the camera board.
    Pregunta a FixBot
    Agregar Comentario
  11. iMac G5 17" Model A1144 Front Bezel Replacement: paso 11, imagen 1 de 1
    • Remove the two T6 Torx screws securing the camera board to the front bezel.
    Pregunta a FixBot
    Agregar Comentario
  12. iMac G5 17" Model A1144 Front Bezel Replacement: paso 12, imagen 1 de 1
    • Lift the camera board out from the front bezel.
    Pregunta a FixBot
    Agregar Comentario
  13. iMac G5 17" Model A1144 Front Bezel Replacement, Microphone: paso 13, imagen 1 de 1
    • Use a spudger to pry the microphone off the adhesive holding it to the front bezel.
    Pregunta a FixBot
    Agregar Comentario
  14. iMac G5 17" Model A1144 Front Bezel Replacement, Front Bezel: paso 14, imagen 1 de 1
    • Front bezel remains.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
2 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 85
Todo El Tiempo: 8,815
