Saltar al contenido principal
iMac G5 17" Model A1058 Inverter pinout 6 pin
  1. iMac G5 17" Model A1058 Inverter pinout 6 pin, iMac G5 17" Model A1058 Inverter pinout 6 pin: paso 1, imagen 1 de 2 iMac G5 17" Model A1058 Inverter pinout 6 pin, iMac G5 17" Model A1058 Inverter pinout 6 pin: paso 1, imagen 2 de 2
    • That is the G5 17" A1058 Inverter pinout with 6 pins. I took it down myself from the board with a multimeter and the ICs Datasheets.
    • 12v is the main soruse
    • GND is ground
    • 5V supplyes Op amp on the sheme that gives the niveau of backlight, It cant be lower than 5v so actualy it dosn't regulate the dimm of the light.
    • 5v The second line Gives the Enable signal ot the inverter
    • Dont connect. It goes to a gate of two mos transistors k72 SMD and is protected trought a diod directly after the pin. It should turn on these Transistors but when I give it supply, the backlight goes off and doesn't turn on back again when i remove the supply (I tried 5v) Fixed it with reset of the PSU.
    • 3.3 v. Again goes on set of MOS transistors. Their gates should be capable of taking up to 5-10 volts. But I decided to play it safe. It makes the backlight brighter( that is the light dimmer). Whitout it the backlight works but isnt brighter as it should.
Conclusión
2 personas más completaron esta guía.
Ogi
Miembro Desde 03/04/14
136 Reputación
1 Guía escrita
Un comentario
You connect the 5v without the GND? The GND is just connected to 12v??? I just see 1 cable making the 5v. HELP!
Lidia Batista - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 35
Todo El Tiempo: 4,669
