Introducción
Replace the display in your iMac.
Qué necesitas
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Slide the inverter-to-display cable connector from under the metal clip on the midplane.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
28 personas más completaron esta guía.
