Herramientas
Partes
No se requieren partes.
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Remove the 2 torx 10mm screws on the EMI shield
Carefully remove shield and copper tape
Peel back the white paper, revealing the screws that connect the hard drive to the carrier.
Remove the 4 T-10 5mm screws connecting the hard drive and frame. (There are 2 screws on each side)
18 personas más completaron esta guía.
