Saltar al contenido principal
iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement
Qué necesitas
  1. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: paso 1, imagen 1 de 2 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: paso 1, imagen 2 de 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement: paso 2, imagen 1 de 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: paso 3, imagen 1 de 2 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: paso 3, imagen 2 de 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
Conclusión
10 personas más completaron esta guía.
Ryan Kozak
Miembro Desde 10/10/11
1,675 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-32, Amido Fall 2011 Miembro de Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Miembros
8 Guías creadas
2 comentarios
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Canadaram - Contestar
Thanks For catching this Typo! :-)
Ben Capehart -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 5,723
