Introducción
This guide will help you install a hard drive into your iMac G4.
Herramientas
Partes
No se especificaron partes.
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
Using a Torx #9 screw driver, remove the two 8.77mm screws holding the drive's shield onto your iMac G4.
Remove the drive shield from your iMac.
Using a Torx #10 screw driver, remove the four 6.03mm screws mounting the hard drive to the assembly.
35 personas más completaron esta guía.
Un Comentario
This guide was very easy to follow and to the point. Thank you so very much for putting your time in creating it, you helped me! :-)
