Saltar al contenido principal
iMac G3 Model M4984 Power Supply Replacement
Qué necesitas
  1. iMac G3 Model M4984 Power Supply Replacement, Logic Board: paso 1, imagen 1 de 1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Power Supply Replacement: paso 2, imagen 1 de 1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Power Supply Replacement: paso 3, imagen 1 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 3, imagen 2 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 3, imagen 3 de 3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Power Supply Replacement: paso 4, imagen 1 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 4, imagen 2 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 4, imagen 3 de 3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Power Supply Replacement: paso 5, imagen 1 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 5, imagen 2 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 5, imagen 3 de 3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Power Supply Replacement: paso 6, imagen 1 de 2 iMac G3 Model M4984 Power Supply Replacement: paso 6, imagen 2 de 2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Power Supply Replacement: paso 7, imagen 1 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 7, imagen 2 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 7, imagen 3 de 3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Power Supply Replacement: paso 8, imagen 1 de 1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Power Supply Replacement, Power Supply: paso 9, imagen 1 de 3 iMac G3 Model M4984 Power Supply Replacement, Power Supply: paso 9, imagen 2 de 3 iMac G3 Model M4984 Power Supply Replacement, Power Supply: paso 9, imagen 3 de 3
    • Now, remove these screws.
    • Now, lift the bottom cover off.
  10. iMac G3 Model M4984 Power Supply Replacement: paso 10, imagen 1 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 10, imagen 2 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 10, imagen 3 de 3
    • Removing the front bezel:
    • There isn't a great position to put the iMac in to remove the front bezel. I recommend flipping it so it it like it would normally be positioned.
    • Remove these two Phillips screws.
    • Now, work your way around the bezel with a flathead screwdriver, and then, pivot it up towards the top, and remove it.
  11. iMac G3 Model M4984 Power Supply Replacement: paso 11, imagen 1 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 11, imagen 2 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 11, imagen 3 de 3
    • Removing the translucent plastic:
    • Removal of the front bezel will reveal two screw covers on the top, pop them off with a Phillips screwdriver.
    • Now, use a Phillips screwdriver to remove the screws.
    • You can now remove the plastic.
  12. iMac G3 Model M4984 Power Supply Replacement: paso 12, imagen 1 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 12, imagen 2 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 12, imagen 3 de 3
    • Removing the EMI Shield:
    • Remove all 10 of these screws, and lift the EMI Shield off.
  13. iMac G3 Model M4984 Power Supply Replacement: paso 13, imagen 1 de 1
    • Power Supply:
    • Removal of the EMI shield will reveal two major circuit boards.
    • The Display Driver:
    • The Power Supply:
    • The power supply and driver board are dangerous, if you do not know what you are doing, you could severely injure or kill yourself.
  14. iMac G3 Model M4984 Power Supply Replacement: paso 14, imagen 1 de 2 iMac G3 Model M4984 Power Supply Replacement: paso 14, imagen 2 de 2
    • Remove these three screws.
  15. iMac G3 Model M4984 Power Supply Replacement: paso 15, imagen 1 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 15, imagen 2 de 3 iMac G3 Model M4984 Power Supply Replacement: paso 15, imagen 3 de 3
    • Now, swing the board out, and remove the following connectors:
    • AC Power
    • To System Fan
    • Don't remove this. It comes free with the logic board power.
    • To Display Driver
    • The connector that is attatched to the logic board; to remove it, simply thread it through the hole in the metal:
    • Now, you should be able to remove the power supply.
Conclusión
6 personas más completaron esta guía.
Chris Green
Miembro Desde 10/11/09
38,086 Reputación
49 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
Miembros de 329
1,451 Guías creadas
1Guía Comentario
i have exactly this problem with my vintage imac g3 took it to repair shop they said could not find it do you know where i can get this power supply and pay to have it installed
richiezuniga3 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 80
Todo El Tiempo: 23,021
