Introducción
PLEASE READ!
This is a quick and dirty guide without too many explanations for how to fix this. I searched all over trying to find answers and came up with NONE. I made too many mistakes when i finally stumbled onto the fact that the pins EASILY slide out after desoldering it!
I wanted to post this quickly simply to get the word out on how easy of a fix this is. I understand there are no images, because I did not think I would be posting this online and I already finished the job and failed because of my previous mistakes. If I had known what I am posting now, I believe I would have easily succeeded.
Keep in mind that soldering skills are required, but it is a simple soldering task. Be careful not to burn or knock around other connectors as it is cramped on that board.
Qué necesitas
La primera imagen que utilicé vino de este sitio: http: //www.btobey.com/learn/images/imac -...
Este puede ser un conector dentro del iMac u otra placa para piezas. Encontré un conector no utilizado en mi computadora.
Aplique el soldador a la base del pasador roto conectado a la placa del circuito mientras saca las pinzas que están detrás, tirando de él lentamente.
Deslice el pin en el conector deseado hasta que esté firmemente asentado en el interior.
Aplique presión en la base del pasador con las pinzas y vuelva a soldar el pasador en su lugar.
Un agradecimiento especial a estos traductores:
100%
¡ Miguel nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
